Ben88
- Lancashire
Ben, what tools do you have? You will need a set of dividers and a set of trammels to mark out a square to round.
Steel rule, tape measure, dot punch and a scriber will be handy as well as a sheet of metal.
If your up for it I'll run through it a stage at a time.
That sounds like a plan, i just need the trammels an the sheet metal (what size would you suggest bearing in mind i'll be doing it in the shed) an i'm good to go,
Christ it's bad that the sheet metal worker here is evidently the rustiest at doing square to rounds! Need to have a bash again sometime, it's been a couple of years since I had to do one last
I've never even attempted to do one you learn what you need to learn on the job an 75% of my time is welding. So i'd only class myself as semi skilled fabricator
) isn't planar, ie they would each need a diagonal bend across them, like this:
