Hi, I'm making an adjustable post to shore up my roof rafters so I can replace the rotten beams underneath. I've found an 8 cm round post onto which I will weld a 4 ton hydraulic jack to raise and lower the rafters. The problem is that I need to cut the ends square to weld on a plate so I can mount the jack on it. Both ends of the post have jagged ends.
How do I make a cut on the post so that its perpendicular to the end? I don't have a fancy cut-off saw or band saw, only my trusty old green bosch angle grinder. I've thought of putting a can or piece of plastic sewage pipe over the postand tracing around it, but I dont have one the right size. How would you do it?
