S Samuealle New Member Messages 9 Feb 15, 2012 #1 Morning all, Im planning to paint some subframes and suspension in this order. bare steel dusting of etch zinc primer stonechip cellulose top coat. Does anyone see any potential issues with this? Thanks Samuealle
steveo3002 Member Messages 8,076 Feb 15, 2012 #2 zinc or etch...not both then stonechip never goes rock hard so its likley to mark when fitting id go primer (epoxy would be best) then chassis black or rustoleum combi
S Samuealle New Member Messages 9 Feb 15, 2012 #3 Okay thanks Steve. I take it zinc sticks well then? The issue i have is that I want to use the existing paint as its the correct colour for my application. Would I be able to overcoat chassis black with cellulose?
steveo3002 Member Messages 8,076 Feb 15, 2012 #4 for the zinc to be any benefit it would have to go on the steel , thats what i was getting at , so use one or the other ...epoxy sticks the best if you want it body colour then skip the chassis black , go straight over the primer or use the stonechip if you wish
S Samuealle New Member Messages 9 Feb 15, 2012 #5 Thanks for the input steve. Zinc -> stonechip -> celly it is then. Worst case is its chips to bits ill just have them off again. Its a mini and the way i do brake lines ect ect its not a great issue to drop them out. Will one good medium coat of stone chip from the gun do?
steveo3002 Member Messages 8,076 Feb 15, 2012 #6 yeah maybe try a test coat on something to see if you like the finish , i often thin it a little bit and use fairly high pressure for a smoother look or if you want stippled effect turn the pressure down so its just splattering out dont put too much on , it will take forever to dry
Weldinator Astalavista baby.... Messages 770 Feb 16, 2012 #7 A token was missing when trying to upload them ?? Is it ok to have a little standard primer on the stone chip from overspray before top coat is applied ? Here's mine in 2k epoxy primer and paint. Ive used Photobucket because the forum loading wont work. Last edited: Feb 16, 2012
