doesn't have iso in itPhew! thanks , how about spraying epoxy, I've been using air fed for this but couldn't see any reference to iscyanates
still best practise to breath in only airThanks again, thats reassuring , whats the best way to test its flashed off ?With top coats,you really need to go in briefly after about 10 minutes and see if its flashed off ready for the next coat. then re mask and paint as soon as its flashed. Shouldn't come to any harm then but don't hang about until its fully aired out post final coat. you will still smell the solvents tomorrow.
they are industrial booths though, nothing like spraying at home in a garage. a pro booth should have the clearance time on itHave look on the HSE website lots of info on there about times for evacuation of spray booths etc.
spray booths require massive amounts of air flow anywhere from 800 cfm there are some much much biggerI spray with the garage door open and it clears in no time, less dust but more prone to flys.
I tried with the garage door shut to start with and used 2.4kw of extraction and it took a long time to clear.
