rusty69bus
moving to the goldcoast
- limbo
i take it that basically all a spool gun is, is a wire fire connected to a trigger mechanisuim.
having just pulled apart a monomig 101(perfectly working) this looks like something that could be made fairly easily
euro fitting would be a good idea just for gas and power connections,then pull apart torch and lead,insert geared wire feed and add a reel holder, then using sticky backed plastic and tape connect back together.
.euro fitting would be a good idea just for gas and power connections,then pull apart torch and lead,insert geared wire feed and add a reel holder, then using sticky backed plastic and tape connect back together.
. I said the exact thing a few years back on another forum and people thought i was an idiot for thinking that the wire speed increased as the spool was running down. Thanks...Bob
, should have remembered that seeing as I picked it up for you
