I have just put a magnum 100sg spool gun on to my weld pak 175. Lincoln said it can't be done.Yes it can be done.You need a 15 volt 1.5 amp power supply to start. Then build a 1.5 to 13.8 variable control into a small utility box.Its easy with a lm217 chip. You also need the mate to the amp connector on the spool gun,it can be ordered at any electronic supplyer.You can do this with no modes to the spool gun or welder. Next you need a dpst small relay.This fires the welder and the wire feed motor in the spool gun.let me know if anyone needs more info.
Mell1051
Mell1051
