At least you can take out draws in Bisleys to relocate them.Yes, the 15 drawer Bisleys are very useful. However, if you wanted to relocate one, would you need to empty it? I've seen one or two which have split down the seams. They were mostly intended for storing paper, and if you fill them with nuts and bolts, I think the shells struggle with any attempt to move them. There are some similar types to the Bisleys which prevent the drawers from being pulled out to the point of falling out (which the Bisleys do); good for storing delicate stuff.
Moved mine several times. As you say. Stack the drawers elsewhere and move the cabAt least you can take out draws in Bisleys to relocate them.
OK; so I've got mostly Bisleys, stuffed with "hardware" and then one or two of the type that cannot be pulled out, stuffed mostly with glass stuff (lab equipment). Perfect!At least you can take out draws in Bisleys to relocate them.
It's getting it all sorted that's the problem. LolWe use Bisley draws, Heavy duty racking from Facebook and proper industrial plastic bins bought from a regular auto jumble bloke, each rack holds 24 bins so once all sorted it will be much easier to find stuff
Come in handy even if I never use it. My life's mantra.Story of my life.
Ooh this will be useful / I can't bin that...
Yes, over the years trying sort storage out, I have felt sometimes that I was "shuffling deck chairs on the Titanic". My problem really started when I closed down the small lab/workshop I ran. Much of what I had was of no great value; some went in to the skip, but loads of it came back home, and the house, the garage and the double carport were choka. Anyway, that was 14 years ago, and things are much better... but it is still a "work in progress". Problem is... I keep buying stuffIt's getting it all sorted that's the problem. Lol
.I have a few of these that I 'borrowed' from a former place of work.View attachment 313639
Not at all as I just lift off the upper ones.....Bet it's tricky sorting through the contents of the bottom one.....![]()
Wish I'd kept them now for storage. Could have easily kept them.
Honesty, the best policy.![]()
