Richard07
- England
I made up a lead today to run the mma side of my inverter. Ran a few beads with various rod sizes to see how it went, everything was fine, ran great. So the i switched back to mig to carry on with the current project, i didnt touch any of the mig settings. Now im getting allot of black soot around the outside of the welds. Checked my gas, comming though fine at 10 lpm, shroud isnt clogged. I clean the beads up and they look fine. Also switched from argoshield light to pure co2, it was a little better so switched back to the argo shield and it was still sooty. Also, when i started welding with the mig tonight the regulator needle was chattering while i was welding, i turned the pressure up and it started flowing normally. Any ideas?
Does Sweep grind up after him ? I sometimes get the rattling regulator but it doesn't cause any problems. Can you borrow a reg to try out on your argoshield ?
Played around any way with settings and stuff, ended up with exactly the same settings as i was using beffore, a little bit of a brownish deposit around the weld but im not worried about that. All the metal was clean so it cant have been from contaminates, dont think it was the wire as i use it most days and doesnt sit long enough to rust. Condensation on the the steel? Would the cold wether affect the gas cylinder or regulator in any way?
