Tony64galaxie
New Member
I have a Lincoln gas mig welder 220 it use to work great and then it started acting up, every time I go to lay a bead down it leaves little bubble welds that break off right away what can be causing this? It welds the same weather I have the gas on or off, I have the correct spoil in the welder the gun is going to the positive and ground to negative, what can be causing this? Heat Is all the way up and wore speed is almost at 2 anything hire and the welder just starts spitting any help would be great thank you
