NTwoO
More skill with grinder than welder
Here are some impressive projects. At least the guys are doing more than ******* up and sitting in front of the TV watching dancing with the stars.
The one with the turbo's under the seat is also dead in the water.Gasless wire, cheap MIG, and straight tubes aren't going to end up pretty, though a lot of the things shown ought to work.
. i know for a fact some farrari's and some mgf's have vac operated butterflys on the exhaust to give a less restricted exhaust after a certain rpm. watch vids on youtube and you can hear quite clearly when they openGasless wire, cheap MIG, and straight tubes aren't going to end up pretty, though a lot of the things shown ought to work. Not the raised 4x4s - I'll give them that.
I like the one with the little cable operated valve bypassing the exhaust. I've got a Pierburg vacuum operated valve in the garage. Diameter is about three times what I need for the Renault, but it would be fun to play with exhausts altered by engine vacuum. They still need a little bit of silencing after (or before) the valve, but not much.
