gaz1
- westyorkshire
if set to open all your heat rushes upstairs and therefore the heat downstairs is poorThis radiator balancing malarkey in domestic systems has never sat comfortably in my mind. I'm not saying that it doesn't work at the time it's done, because it does work, and is necessary if there aren't any TRVs on the radiators themselves. But, in the longer term, the flow restriction can be a place where blockages can occur. It only takes a couple of lumps of magnetite, or some other contaminant, larger than the size of the restriction, to lodge at that point and start the blocking process. I prefer systems where there are TRVs on every radiator, except one, lockshield valves more or less open and, once a room comes up to temperature, the TRV reduces the flow to the rad, allowing a greater share of the flow to reach the remaining radiators on the circuit. Yes, the room(s) with the initially flow-starved radiators take a bit longer to reap the benefits, but they get there, usually within half an hour, or so of the heating coming on.
A thermal camera can be very useful for visualising heat flows in radiators.
Out of interest, does the system gurgle much when it's on?
it also rushes to the closest point and returns via that way so a long distance rad remains cold so balancing is the required remedy
slow the flow to upstairs then feeds the heat downstairs the same can be said for the longest distance away from the boiler
even the hot water cylinders have to be balanced otherwise the full flow goes through that and back to the boiler on the quickest shortest route
trvs only control the flow until that room becomes warm enough then shuts down then feeds the other rads but that means your central heating needs to be on for a full hr compared to 15-20 mins and all rads up to full temp when the system is balanced properly
the inhibitors can and dose block the system where the valves are set lower on the return flow as some inhibitors have a sealer within them for sealing small leaksAs for crap in the system – fit a filter, use inhibitor. My filter pulled an enormous amount of crap out of the system in the first few weeks of having fitted it, then pretty much nothing from then on.
get any sludge or small particles that build up and it acts like a small leak of water and thats where the sealer starts to block the flow
opening and closing the return valve dislodges this effect if you open and close that valve a few times and then reset the valve to the same point
