- SW Scotland
Once you've got it in a vector format then you're going to be extremely happyyeah I know - but it doesn't half look good on the screen, and you really do need to get close to read the text.
Its not bad its only 47 meg....lolTurn down the resolution, that's ~1600 dpi!!!! No wonder you're running out of memory on an average domestic PC. Even a detailed A4 diagram should not need more than 600 dpi and 300 dpi will be adequate for 95% of occasions.
Nope its no good....Its not bad its only 47 meg....lol
I have converted it to an eps and an svg. SVG opens fine and is scalable so I think it might sort rtbcomp out.
Confused. when I open it it does not show any nodes...That opens fine, it's slow refreshing &c and there are a lot of nodes, the markers tend to obstruct the image.
I think the best bet is to reduce the size until it loads correctly and then pick out the bits I need.
Thanks for your help, much appreciated.
Inkscape but I cant get the nodes to show..lolI'm opening it Inkscape, what are you opening it in? The nodes show when I click the Bezier/Line button.
This is the latest one opened in inkscape.I'm opening it Inkscape, what are you opening it in? The nodes show when I click the Bezier/Line button.
I'm happy to have a look at it in illustrator if your not in a great rush.
