Soft welding rod.
  1. balmerchris
    balmerchris barnacle picker
    610
    Co. Armagh
    I have to build up wear on some shafts, nothing critical. I would rather the shaft wear out again than the hole it goes in as it is an easier repair. Is there a specific rod that would be soft or would 6013 be OK?
  2. Brad93
    Brad93 M J B Engineering
    7,434
    Essex
    You need to look at the data sheets for the consumable.
    Do you know the hardness of the hole or shaft? Without that it’s going to be difficult to assess what hardness your consumable needs to be
  3. balmerchris
    610
    Co. Armagh
    Pretty sure it's mild steel. It's for the tine holders on a haybob.
  4. Brad93
    7,434
    Essex
    Then you’ll always get galling and therefore wear between the two.
    A weld deposit is likely going to be harder than pure mild steel.
    balmerchris likes this.
  5. Wildefalcon Member
    205
    Gloucestershire, England
    Could you sleeve the tine? With mild steel tube? That way you've a sacrificial part you could change each season.
    Lots of copper grease and some grooves in the sleeves for a puller would make it a simple job.
    slim_boy_fat likes this.
  6. TechnicAl
    TechnicAl Member
    7,089
    Rotherham
    Lincoln Smitweld used to do an Armco Iron rod called KARDO (i think)....ring Lincoln and ask for Dave Senogles
Advertisements
