What exactly are they doing at 7 mins? Placing timber uprights in the excavated holes and filing with dry mix.....?? Surely not
What exactly are they doing at 7 mins? Placing timber uprights in the excavated holes and filing with dry mix.....?? Surely not![]()
No one said the groundwork was done the same day.not even that was done in a day the ground work alone to get it right in the first place had to be done right
so certainly not a day
as long as you have a framework you can build anything in a day including a house frame or large shed even if it was built on concrete
come on Gaz, don't be that guy, it's not cool.not even that was done in a day the ground work alone to get it right in the first place had to be done right
Pole barns are becoming very popular over here, and a crew can really work fast.I wouldn't have believed it if I hadn't seen that video. 1 day 3 hours.... absolutely mad.
Very, very impressive.
My farm shed went up start to finish is 4 days, including ground work and concrete floor, but there was 4 weeks between day 1 footings and the 3 day build. 16 hour days though.come on Gaz, don't be that guy, it's not cool.
Anyone who has put up any form of decent size shed knows how very impressive that was.
It took me and my brother 3 days to put up just the steelwork and purlins for a shed that was only a little bit bigger than that. Never mind roofing and sheeting!
To do what that crew did, every member of the crew have to be skilled, organized and experienced.
what makes it a real "shed" ?It's not really a shed is it but still impressive.
The other important factor is it was an Armatish gang that did most of the build, the Armatish have builds like this down to a fine art and speed.
Good question but I think most would not consider it a " shed ".what makes it a real "shed" ?
Why ?Good question but I think most would not consider it a " shed ".
Do you think is a shed?Why ?
This is a "shed", they bring it in on a trailer pulled behind an f-250......Do you think is a shed?
Sure looks like a shed to me…….and the dictionary has a few meanings!Do you think is a shed?
