Reassuring ツ
Those who has tiles, did you have them installed by a specialist or general builder or DIY?
And with the welding splatter, do they just get marked superficially or is it actual damage? I'll just have to use a welding mat.
My BIL has just painted the new floor in his garage with polyurethane paint and the finish looked perfect until he tried to wash it with water and found the colour pigment had not sealed properly. He took it all up with a razor blade and read up on it and apparently you have to make sure the lattice on the top of the cement has been lifted as this is like an impermeably barrier to anything. You have to remove the fines from the surface of the concrete either by pressure washing, acid etching, scrubbing with a wire brush, foot traffic or continuous exposure to the elements. Once he stripped the floor he said he could see the fines attached to the back of the paint which came up in sheets and where it was looking different he scrubbed it with a wire brush. The second time it was painted it was perfect and cured without issue.Properly sealing a concrete floor still costs money, I think it was a few hundred for my floor, same as the tiles (though the tiles still have additional install costs and adhesive cost). Without sealer it dusts. A few people on here have complained about epoxy paint just peeling off like a rubber sheet. Tiles just feel like a forever solution that isn't much more expensive that epoxy or sealing.
Sounds like that Mr Bean episode where he masked off all his furniture and ornaments to paint the roomOK, here's a tale...![]()
OP, Not all porcelain tiles are created equal you get glazed and unglazed rectified and honed, "Garage" tiles are often showroom tiles rather than an industrial floor covering. cheaper ones are "Gres" which is a thin grey porcelain with a glaze , glaze is just a layer of coloured glass and so is susceptible to chipping scratching and will hold on to grinder and welder spatter like a windscreen. Unglazed will be better (its the same sort of stuff pink tig shrouds are made of) any colour will be through the body of the tile so chips and scratches wont show as much. Honed while looking Shiny opens up the grain of the ceramic and will stain or hold on to grease, which will be tricky when you spill water or have wet boots.
Fitting - isnt rocket science but its 99% prep and materials. it has to be a flexible or Porcelain compliant adhesive and must be cement based ideally mixed with an electric whisk to activate the additives. Grout must be quality flexible stuff too - adhesives and grout have very different properties and so all in one stuff is pointless and usually dear. if the floor is uneven then spend a bit on a self levelling compound as its much much cheaper in the long run than trying to level up a floor with expensive adhesive and youll just end up in a mess with lipped tiles.
trowel dictates adhesive bed a 10mm trowel at 45* gives a 5mm notch which will slump to 3mm bed when the tile is placed. Adhesive has to be mixed to a soft consistency. fast set can go off in about 15 minutes so if your not good at what your doing you could get in to trouble !
Any idea how much a pro would charge for doing 30 sq.m?
so here's how to do it![]()
Right enough work...can i go back to Beer, mince pies and slow-mo CNC machines on you tube?
