Robert1998
- Spain
The bore has not been machined concentric to the outside diameter or the gear/pulley is too loose on the shaft, throwing it off.
I should have said bore not machines perpendicular to the gear then.A non-concentric bore would lead to vertical movement of the gear, loosening and tightening the mesh. His arrows show a horizontal movement.
Looseness on the shaft, as you say, will have undesirable effects.
As it is a compound gear, it is possible that the keyed bush onto which the two gears fit is a little too long. That could allow left-right movement of the gears on the bush even though its securing nut is tight.
There is not really sufficient information in the original post to identify the problem. If we take his left-right arrows literally, he is only showing lateral movement. If the top can go left while the bottom goes right, there is rotational movement.
... I realized that the tailstock is not totally centered with the spindle. if I put near the spindle, is 0,2 or 0,3 mm over the center...
The problem will be a chuck problem holding the bar and given that it is a 3 jaw then to be honest what you have there in relation to center differences after moving is pretty goodEDITED: Ok, I have tried with the dead center and I think everithing is OK. Because everytime I extract and put again the dead center in the headstock spindle, the position change, so the problme must be smaall irregularities.
But there is no problem if the work is 0,1 or 0,2 mm out the center, right?
And thank you again for all your help, this forum is great
