Robert1998
- Spain
The bore has not been machined concentric to the outside diameter or the gear/pulley is too loose on the shaft, throwing it off.
... I realized that the tailstock is not totally centered with the spindle. if I put near the spindle, is 0,2 or 0,3 mm over the center...
The problem will be a chuck problem holding the bar and given that it is a 3 jaw then to be honest what you have there in relation to center differences after moving is pretty goodEDITED: Ok, I have tried with the dead center and I think everithing is OK. Because everytime I extract and put again the dead center in the headstock spindle, the position change, so the problme must be smaall irregularities.
But there is no problem if the work is 0,1 or 0,2 mm out the center, right?
And thank you again for all your help, this forum is great
