blenkie1
So your doing proper gates for nearly as cheap as the cheap imports out of the thinnest stuff imaginable
How the heck did you make any money? If we work on you needing £100 min for labour and overheads per gate it don't leave much for steel and galv before your double the cost. Trying to pull even a 25 k wage is nearly impossible and if your gates are any good they should last twenty years or more
Compare that with a gate for someone in town across thier drive and it's a no brainer
The first gate I made for a farmer was just simple 50x50x3mm box 12' long. When I first went he had maybe 10 gates sitting in a pile all mangled all made from light tube made by IAE or Ritchies. He said he was paying just under £100 for them. Can't compete with that all galv as well. Trouble was some of them gates were not lasting a year the steel was so light I've seen thicker car bodywork! The thing is these have to keep cows in that probably weigh the same as a small elephant. What he wanted was gates that was going to hold them. The bulls simply push the gates out of the way or try to jump them. One of the bulls bulled a heifer that was only a year old. Had to get vet out. So destroyed farm gate, Vet bills and hassle what I charge is a bargin. He said one of the bulls tried to jump my gate (it was higher to his requirements) landed on top the gate bounced a bit but had no damage what so ever. Saved him money already. After that he replaced them all. It was easy money. It just a heavy basic gate make one and you have your jig to make the rest its just a production line. Nearly all standard sizes 8',10',12'. Got the steel at discount I was buying so much. Me and the wife spent a day cutting and then the rest of the time making. The hardest part was drilling 2 holes and making a catch. Was not bothered with gal so I just sprayed them to the colour he wanted.
From that one job it snowballed. The Vets were coming and seen how safe they were compared to normal gates and spread the word and other farmers seen them and wanted them made and then wanted other work done, trailers, feed barriers, stuff they cannot do or maybe too much hassle for them. Yes I heard they can be bad payers but touch wood I have not had any problems in fact some times they are chasing me! Yes a lot of farmers can weld but its normally to weld some hooks on or a small repair something thats really not worthwhile for me to do anyhow. I was welding/fixing combines the first year I started. Not got the overheads of a normal agri engineer so I can charge less. Started doing hose repairs the 2nd year after seeing what hose replacement cost. Most of it is just basic, simple work nothing hard. My biggest failing is I need a good press brake to start moving into other areas.
Kent, your business works for you with what you do and I wish you good luck in it but don't discount agri work someone has to do it and I can only speak from my experience but it worked for me and I started about 4 years ago. Work out whats near to you. If its all agri stuff try/start with that, if its forestry then head in that direction. A local blacksmith sometimes works for me because around here its all rural and just not enough work to keep him going.
