is there anyway to calculate ideal O-ring size from bore and shaft diameter?
Have a gander at an oring calculator Brad, you can switch between piston, rod and axial use.
O-ring Calculator
Do you need an O-ring? Use our interactive and user friendly calculator tool to help select the optimum size O-ring for your application.ceetak.com
Bob
Got badly caught by that, needed a couple of rings to rebuild the ram on an engine crane; minimum order £12 plus £4.95 p and p. £17 for a couple of 'O' rings. The main seal, I got from Amazon of all places, for pence.I have one of these, it's not perfect but can help a lot, sometimes you'll need to go a size either way.
O Ring Measuring Gauge BS1806, AS568 Range. Imperial. New. Boxed. UK. | eBay UK
BS1806, AS568 Range. Bonded Washers - Imperial. O Rings - Imperial. O Ring Gauge. The AS size of small o rings can be found by matching them with the silhouettes at the side of the gauge. For the larger o rings, place the o ring over the grooves under your identified slot and pull taut.www.ebay.co.uk
O rings are cheap as chips but most places understandably have minimum quantities for a size which can start to stack up if you are buying one size either way.
That's exactly what it is yes extruder manifold for a bakeryIn a very similar style of use, but with gearboxes, we've stuck 'em in place with grease - so assuming that's some form of food industry extruder manifold, a smidgen of food safe grease?
