Maddog
- Manchester
Hi chaps.
Have started to rebuild an old trailer today. Fired up the welder and after a few mins of welding on and off it stopped feeding, now it's done this before and usually a light tap with a foot gets it going again... But tonight it stopped for good. I know it sounds like a loose connection of some kind, but I've been through the whole welder with a fine tooth comb and all seems well. I've also previously modified it with an additional cooling fan so it doesn't get too hot. I don't think thermal cutout is the issue anyway as its only around 7 degrees here anyway.
Any ideas what else could cause this. Could it be a problem with the motor? As its not even trying to feed. I've previously had the motor out and connected it to a battery and it spins ok. Don't really want to replace it as its not a bad little welder when it works and it was free.
Cheers.
Cheers.
