Flea bay or try Ali expressAny one know where I can get a Dinse Dinze Connector Welding Panel Socket Female 16 25 mm
cheers Kev
cheers Kev
Hey John,Hi Kev. As Hutcho says there's gazillions of them on Ebay so you can take your choice or Amazon have plenty too. I've bought from both.
Only thing I'd say is that among the last few I bought (I can't remember where from now) some were a bit of a problem. The plastic surround that sticks out of the case front was too long for the male connectors on the cables to push in far enough to turn and lock in place. They are obviously from China and we all know about quality control there!
I actually ended up filing away a piece of the little jobby on the side of the male pin thing so it would turn (please excuse the technical terms) thinking it was the male pins at fault but later found other Dinse plugs also wouldn't turn.
A sanding disc to reduce the socket stickout would have been a better plan.
John
It is possible that a 195 Amp MIG welder would trip the breaker on the higher power settings, simply due to the transformer inrush current. This can happen even if the machine is not actually faulty, and even if you are not welding, its just idle and you press the torch trigger. However, the first issue to investigate would be the rating and Type of the circuit breaker.Apologies I should state my machine is a sip 195 turbo
