decepticon
hi,
i have some 2g welding to do with a single v with 10mm plate (incase some one is not sure the 2 plates are standing vertically and the grove runs horizontally) and was trying to find out what technique others use? on a vertical up single v i would do a U shaped motion with the rod-what is best for 2g? would you prep plates at 30deg? should the rod be angled upwards?
i have some practice time and want make sure technique is correct before i start
will root with filarc 56s
cheers
neil
cheers
neil
