Craig-SM
- Heckmondwike
Yeah, battery manufacturers.
This is effectively already where we are in terms of manufacturing.
Basically every brand uses the same designs of cell from the same handful of far eastern manufacturers, in more or less the same arrangement, but for the mechanical design of the connection.
The small differences in battery chemistry for premium batteries from the likes of Milwaukee don't matter to the connection standard.
This is exactly it, it serves their needs very well, but acts as a barrier to consumer choice, and reduces the drive to compete on quality or functionality.
Which in turn allows the big 3 players to capture a disproportionate amount of new entrants by offering extremely cheap deals on kits of 2 common first tools, two batteries and a charger (often cheaper than the two batteries alone would be at RRP).
Having secured that customer, they can then act as rentiers because having bought into that brand, their customers are heavily disincentivised to switch due to cost.
If I could justify the expense there's quite a few tools where I know Milwaukee, DeWalt, or Ingersol Rand would be far better than the Makita I do use, but I am locked in by cost.
Hikoki/Metabo HPT do a ¾ impact wrench that puts all the other manufacturers to shame in terms of size and performance... But because they don't have the same range of tools or market penetration, it's been unable move the needle on sales.
But they could still have whatever battery shape they like (if they deemed it worthwhile to make their own batteries still, being festool they probably would).
All that's required is to have a specific agreed connector and latch, which would constrain only a tiny portion of the form factor, the part which inevitably ends up buried inside the tool anyway.
That's exactly like the standardisation of USB C
I don't understand how standardising the battery connector would impact on a wireless communication protocol.
But then I also don't understand why a battery needs Bluetooth to begin with.
Are there really meaningful differences in most of the core products at the moment?
I would argue not, If you buy a drill in red, teal, yellow, black & green, grey & red, green, blue, or neon green it will still weigh about so much, and drill holes in much the same way.
- Metabo HPT/Hikoki, Bosch, etc. don't really have a stand out product, or much market presence,
- DeWalt has nothing unique either, but stands out with sheer market power, being a very big name,
- Makita makes a few niche industrial tools, but only really stands out mostly by market power, as another big name.
There's then two differentiation strategies:
Cost,
- Ryobi makes everything a bit more affordably than everyone else,
- but that strategy is losing ground to "Fakita" and "Milfakee" as the Chinese OEM's start to sell decent products on an existing battery platforms directly,
Specialisation,
- Milwaukee has really invested in developing the widest possible range of speciality tools for specific trades, but the core products are still basically fungible with every other brand.
- Ingersoll-Rand makes the same range of manufacturing focused specialist assembly tools and absolutely massive impact wrenches as they offer in air-power.
- Hilti and Festool have really focused on unique products for a specific trade and optimising their other products for the trade who would buy into the system because of those unique products.
- Metabo (not HPT, the German one) makes truly excellent angle grinders, and thoroughly mediocre everything else.
So a common battery connector would change basically nothing in terms of the individual companies marketing and product development strategies.
But would:
- open the door for some of the under-represented brands to find a specialism if they wanted,
- allow consumers to mix and match to get the best tool (and best battery pack ergonomics) for each of their needs.
Dual battery 36V tools are a just a special case of 18V tools for connector purposes...
It would also be possible to have a shared mechanical connection standard for 18V/36V which uses a different pin arrangement for the two voltages, so the tool side connector determines which is used.
That would enable all dual 18V battery tools to also run on a single 36V battery, and allow an 18V tool to use a 36V battery as a double capacity battery (as per Hikoki's implementation).
As per my above comment the design details past the connector doesn't really matter for standardisation.
The manufacturer is then free to go wild with all manner of designs and form factors for the pack itself in a quest to sell their own "special-sauce" batteries to the people to whom it will make enough difference to pony up.
If the desire/need is there, including data pins as an optional feature in a standard would be easy, and could even use an existing industrial communication protocol to avoid conflict over what pinout to use, and take advantage of mass manufactured IC's.
The reality is that a standardisation attempt would most likely end with:
- 12V using an inserted connector to allow for the tiny "magazine style" batteries that justify 12V tools (a la Milwaukee)
- 18V and 36V would end up with a slide on type (similar to Milwaukee, Makita, DeWalt, Hikoki, Festool, Ingersoll, et al), quite possibly a shared standard for both voltages.
The standardised battery can be any form or size now so long as it the connections to the tool are the same in which case from your earlier comment there are 3D printed adapters so why bother creating a standard when you can take your Makita battery and connect it to a Milwaukee tool with the little adapter.
I’m happy with my battery platform and the tool range available. I'm pretty sure I wouldn’t be so happy if they became obsolete because they had to adopt a different battery platform.
