If the shell is sound and lined up you don't need them to be adjustable, either just cut a straight bar that bolts on or even simpler just tack a bar across and then remove it once you're finished. The only benefit of a lot of the pro door bars is that you can keep the door on to check gaps, but if you're clever you can still do this using the method above.
