Afternoon All,
I hope you are all well?
I have built a few electric bikes over the years and on this current build I would love to customise my full suspension t6061 aluminium frame (mega chunky orange patriot 7+) for housing a battery (part of the reason i started my level 2 welding course last year in fact), however, I am told various things by various well qualified and experienced folks about the situation post welding....
Welding will weaken the frame in and around the HAZ of the welds...I have heard up to 70% loss of yield strength but most research I found shows 50%.
options so far as I can tell are:
1) meh it's only a bike frame and overbuilt anyway so just run it as welded and it hopefully will be fine
2) it definitely needs baking and quenching by pros which a) sounds expensive and b) will need to putting in a jig to prevent deformation
3) shot peening appears on the surface (no pun intended) to be a half way place between baking it and leaving it as welded as it returns about 10% of the yield strength and increases fatigue life post weld as well as baking it does. Also it seems much much cheaper without the need for being in a jig to prevent deformation....this is my preferred route if it can work.
I have spoken with bike manufacturers, local engineers and an aircraft engineer and tool maker and all have different opinions from it'll be fine as welded to yes it definitely needs baking and quenching....which obviously leaves me confused...
Any help, experience or thoughts on any of this is much appreciated...
Thanks guys
Thanks guys
