Shot blasting booth
  1. Keithedw Member
    34
    Wirral
    After a bit of info ....thinking of building a shot blast booth big enough to blast alloys ,gates and big enough for a car shell .
    What would be the ideal size for a compressor and what size dust extractor would I need ?
    Cheers Keith
  2. Mee Banned
    1,441
    Here and There
    For a car shell I would construct a simple frame and cover with a tarpaulin, you need a lot of CFM for blasting and a lot of extraction.
  3. rtbcomp
    rtbcomp Moderator Staff Member
    18,615
    Sheffield UK
    The size of compressor depends on the size of the nozzle, which in turn depends how fast you want to work. The size of compressor isn't determined by the size of the booth.
    Are you looking doing this as a hobby or business?
    Extraction does depend on the size of the booth, as well as the factors above. I had a 6' x 4' booth with a Clarke 1hp chip extractor. I fitted extra filters to the output to increase flow, but there is room for even more filters to be added.
    You need to seal the doors and edges and provide an inlet for air at the top of the booth and extract from the bottom, opposite to the inlet. You have to aim for a good flow of air rather than a pressure drop.
    This is my extractor setup http://www.mig-welding.co.uk/forum/media/albums/blast-room.301/
    hareng likes this.
  4. brightspark
    brightspark Member
    28,946
    yarm
    a 90cfm comp using a 6mm nozzle is minimum and doing gates wants to be bigger than that unless u have all day to waste faffing about then shell out for an air fed blasting helmet about 180 quid
  5. Keithedw Member
    34
    Wirral
    Hopefully do it as a business I've got room to build something in the region of a 8 x 15 ft booth , was thinking of a 250 -350 cfm compressor setup
Advertisements
