Hi,
I have just bought a Sherman TIG 210 AC / DC Pulse welder used from ebay, however when the button on the torch or the foot pedal is pressed nothing happens - no gas and no attempt for the HF start. It was apparently sent for repair for a similar issue before.
everything is connected and the issue is the same on 2t / 4t and ac/dc. There is continuity when the button is pressed and MMA works fine. Also, the current screen goes up to 400+ amps when everything is turned up. I removed the cover and nothing is burned or leaking or appears damaged.
I knew of the problem before buying so got a good price.
Thanks, George
Thanks, George
