I spent a weekend trying to get Linux to dual boot on a new Win10 machine....what a waste of time. The board had that stupid OS lock that they stick on new machines....very annoying as I wasn't aware of it!
I use bitlocker on all my windows machines....well worth doing to prevent "someone" stealing your PC and lifting the drive out and just reading all your data. BitLocker basically encrypts the drive....am sure Linux has something similar?
Is running Linux in a virtual box not an option?
The key thing is you want the drive to be encrypted....otherwise someone can simply open the PC and pull the drive out and access it directly using another PC. Basically they just access the encrypted data directly....they don't even need to get through your windows password!
What is this OS lock of which you speak? I've never encountered such a thing on any PC I've built - but then I guess it's only on retail machines with a Windows OS as default...what a waste of time. The board had that stupid OS lock that they stick on new machines....very annoying as I wasn't aware of it!
Pretty much.What is this OS lock of which you speak? I've never encountered such a thing on any PC I've built - but then I guess it's only on retail machines with a Windows OS as default...
That would severely on the chips - I always dual boot Windows with Linux.
Whenever I've dual booted each OS has its own drive rather than partitions and I swapped boot priority depending on what I wanted to run.Can't remember the name....its basically being shipped with the motherboard/bios...it's been around for a while I think. I think the idea is that it prevents someone taking control of a PC by overwriting the OS. So basically I think the OS has to be certified...I think if you are just installing one OS then you wouldn't even have noticed it....but when I tried a dual boot install it just freaked out.
Haven't built a rig for years. First gen i7 930 was my last build happily running 4.3ghz on air. Wish I'd have kept it. Would still be a reasonable rig.Yea I was trying to get it to dual boot from a single drive...gave up!
I think dual drives would have been fine (I think).
I also mostly build my own kit too...I built a low power system which uses something crazy like 35w in "normal" use....pretty impressive!
Other than gpu prices seem to be through the roof.I literally just sold mine a few weeks ago....was the original i7 920 with a lovely Asus board and 16GB ram. Ran rock solid....but the power consumption was about 350w and in the summer it was unbearable in my office so I went low power i3 or i5 I think.
Not much has really changed to be honest....buy the bits....throw it together....install OS....done!
How does this Bitlocker work in practice, do you have to type in a longer password every time you boot up your PC?
I've always just used the standard Windows password feature, I don't doubt that it's probably not that secure but I don't understand how encryption works/is that much different??
its been around a while you have to watch out for new mainboards and other gadgets locked as well
however its been beaten
https://www.theregister.co.uk/2016/08/10/microsoft_secure_boot_ms16_100/
also beaware of these things
https://www.theverge.com/2016/1/16/10780876/microsoft-windows-support-policy-new-processors-skylake
https://www.theregister.co.uk/2016/09/02/windows_intel_kaby_lake_amd_zen/
I can assure you the info is accessible
THe password protection wasnt worth bothering with
PHotos and other stuff always have 2 copys of it
Windows passwords offers no data protection at all, if I had your pc I could reset your password and access the files in minutes or put your hard disk in another pc to get the data.
You only need the long key if the OS thinks you're trying to boot it in a different pc, otherwise it's just the windows password to logon.
All our pc's and laptops at work are the same so if something dies we move the hard disk to a working box, enter the bit locker key when prompted and the user logs on as normal.
Bit locker works in one of two ways when it's setup, it either encrypts the whole drive including blank space to protect deleted files or just the current data and new data as it's created. The former is best for a pc that's been used for a while and the latter is quicker on a new machine.
