MikeBs
- Worcester
Hi,
I drill a lot of holes mainly in stainless and mild steel, anything from about 2mm to 4mm thick. They are predominantly 8mm, 10mm and 12mm holes for bolts to fit through.
Its not precision stuff and I use a battery drill with 0-400 RPM and 0-1400 RPM
Prior to reading some info on this site, I had the philosophy of "If its not cutting fast enough then oil it and increase the speed".
I was also unaware of the effects of heat on metal and tempering, hardening etc...
Hence I have abused my HSS drill bits and they now no longer cut well and some not at all. I have tried sharpening them on a grinder, with some success, but they seem to blunt again really quickly.
My first question is - If I have taken a HSS drill bit to a point where there is smoke coming from it, is it just wrecked or can it be resurrected?
I always drill a pilot hole of 3mm - 5mm first, depending on what size I have on the bench. But this size bits are fairly cheap and I treat them as throwaway items.
Its the bigger drills that start to get pricey to replace.
My second question is - Are the expensive carbide drill bits worth it or are they just as easy to wreck or harder to sharpen?
I like to have about 3 or 4 of the larger sizes so if 1 stops cutting I can reach for another one, but getting a stock of carbide drills is an expensive game.
Any advise would be appreciated.
