8ob
- Nescient in the vale
Were you a champion bottle roller ?
There will be a fair few of us on here Parmster
Bob
Im planning to roll a bottle.There will be a fair few of us on here Parmster
Bob
How much more clutter are they going to strap onto a bottle? I was a wizz bottle roller when they just had the tap on the top, cant get to grips with these tap guards and now they have added gauges
Bob
Huh I don't follow tonight.Never underestimate pure Oxygen. Theres not much that is nastier if you throw in a hard 90 or some oil / dirt .
U read that you use less acet compared to polypropOnce you use acet , nothing else will do . You spend more on acet , and save it on your oxy.
I’m on my way to buy stock for this evening
Wouldn't bother with acetylene unless you really need it.
Tig
MIG
Stick
Covers that
pure oxy is potentially deadly , an oxygen fire is very fast and viscous , all it takes is a spot of oil or grease to start an oxy fire and a sharp 90 creates heat due to an effect called adiabatic heat of compression , its like putting your finger over the end of a bike pump to make it squeak , you also burn your finger .... that heat can cause a fire / explosion if you crack open a cylinder of 02 into a tight 90, if you ever watch a gas blender handle pure 02 and a welder handle pure 02 you will see two very different approaches to the same gas. Its not the oxy that burns it just makes it a lot easier for anything else that will burn to do so a lot faster and hotter .Huh I don't follow tonight.
Propane takes much longer to preheat but when it's actually cutting I prefer it to acetylene.I mused the options but don't think I can live without it, recently bought some propane tips for the gas axe so will give them a go.
Bob
Cutting 20mm plate with a grinder is getting tiresome and messyWouldn't bother with acetylene unless you really need it.
Tig
MIG
Stick
Covers that
my plasma wont cut 20mm plate it will just do 10mm messy though! I hear acetylene will pee through 20mmAcetylene is beautiful for cutting compared to propane, it's almost surgical but a plasma cutter is much less fuss. Can't use it for heating things though!
oxy acet will cut up to about four feet thick in steelmy plasma wont cut 20mm plate it will just do 10mm messy though! I hear acetylene will pee through 20mm
Yep, with the right nozzle no problem, and quick.my plasma wont cut 20mm plate it will just do 10mm messy though! I hear acetylene will pee through 20mm
Oxypropane, once the metal is red hot the oxygen is what makes it cut.Cutting 20mm plate with a grinder is getting tiresome and messy
