Pinky
When setting up the spray gun I open the compressor valve on the wall fully open
I have large bore hose goes into the devil biss control box
a small hose to the air fed mask
A wip hose to the gun
I use the regulator attached to the gun to control the air 2 bar
Should I adjust the valve on the wall ?
How do I no I am getting enough air in the mask or to much ?
How do I no if the carbon filter attached to the air fed mask needs replacing
Ho do I no if the air pressure to the gun will stay the same
The compressor is a Clarke air model no SE16C150 10 bar
Thanks pink
Thanks pink
