brightspark
- yarm stockton on tees
get yourself 100 meters of thin orange nylon string
put your (piston for want of a better word) in then a tube blowing air down the pipe it works perfectlywell just my findings----If blowing it though how do you feed the string in ??
Would have to be a really small ferret, its 25mm bore pipeNot joking but find someone who keeps ferrets. Get someone at the far end to rattle a stick a bit in the end or jangle keys if they aint up for it straight off. Harnesses can be bought or a std collar to drag a pull though. Just remember pull cables one at a time and always leave a pull though remaining.
Never heard of Dwarf ferrets??, not only do they run up trouser legs easily , they don't stop at Japanese eyes either.really small ferret
AH HA got it, if using that much air then the 'piston' doesnt need to be a good seal, better if it is not a good seal, in fact so that the air flow carries the 'piston' along and the blow pipe would then form a venturi effect pulling in more air at the feed end including the line.put your (piston for want of a better word) in then a tube blowing air down the pipe it works perfectly
Would have to be a really small ferret, its 25mm bore pipe![]()
