No, it's not that simple. A 2005 Skoda Superb (Passat B5) has sensors front and rear, many of the VAG platforms do. That one was Xenon/Halogen combi, same thing on a 2019 Golf. Unless the car is Halogen only it's a real bugger's muddle, hence having access to VCDS is really helpful. Tells you what modules are fitted and if they're all working.I think it's only the touaregs with air suspension that have sensors on the front axel?
And the levelling is only for the xenon.
The touareg has a dual xenon/halogen arrangement and the self leveling is not active on the halogen main beam, only the low beam xenon.
Unless the OP has bi-xenon but then, if dipped beam is fine, it will be a mechanical problem with the shutter mechanism.
Not always. The various VAG platforms do different things but normally if there is a faulty height sensor it just puts the headlamps into failsafe mode, i.e. on the lowest setting. The exceptions are Lamborghini (completely different) and the ones developed from the Bentley platform such as Phaeton which are also completely different.If there was a detectable fault, wouldn't it put some sort of warning on the dash? most active lighting systems do.
