frank horton
V twins are great but 4"s rule.........
- Crete, Greece
It seems to me that there's a running problem with seized threads........
here's my take on stopping the problem........
Unless Locktite is needed every machine I own, gradually has each screw/bolt removed 1 at a time and put back with a little oil.........
every machine I repair get's the same treatment, anything I unscrew gets cleaned (carb cleaner) and oiled....as I've said before I repair garden machinery and other stuff......make's future jobs much easyer, better for me and the customer........
on small nut's and bolt plus screws up to 6mm, I replace where poss with st/steel fixings.....mostly somebody with the wrong size spanner has taken the corners off anyway......and the the nuts and bolts usually shear, especially around the cutting deck's.........it's hardley more expensive than BZP in the long run.....
For dodgy parts that are hardley removed especially on tractors I use Copper slip BUT it's modified ......
take some out of the new tin and mix in 80w-90 gearbox oil.......JUST A LITTLE....enough to make it like thick cream.......standard copper slip will harden with time and become usless.........the above mixture I learnt at a w/shop that repaired cranes and other equip used in sewerage plants........u can imagine what corrosion problems we had !!!!!!!!!! apart from the smell.........hahaha.......
anyway never had a problem when servicing the undercarrage, ever .....even after years, everything was easy to unscrew.......
On my car lift I keep a tray with dropper bottles filled with Diesel, eng oil, chainsaw oil and WD40........all within easy reach.........
the diesel is used alongside WD40 to soak seized stuff, eng oil as a light general lube and the chain saw oil for stuff that rotaes slowly.......
what u may ask rotates slowly, well for 1 thing the lift screw's on the ramp and the back gears on the lathe.......the lift screw nuts are plastic and still like new after 15 years.....
try it,
with the lathe running on slow with the back gear guard off just dribble a little c/saw oil on the gears, it wet's em down and stick's to the gears like CHILD SNOT......even after weeks of no use they are lubed.....
generally I use Synthetic engine oil in modern stuff except some motorcycles with wet clutches and the old / antique engine get semi-synth......I don't get involved with nackered engines ever.......
there is a crap story going around that 80w-90 g/box oil eats bronze bushings......well in 50 years I've never seen it......
as for lub in lathe gearbox's I only use RED auto transmission oil, I'm not gonna pay for the facory recomended over priced oil.........before u go off on one.......
when ur on the motorway next and that Merc Srinter comes past at 100mph with a ton of crap in the back........WELL they use auto trans fluid in their manuel g/boxes........mine did 200,000 miles with no trouble......
well story time is over and u will have gathered I'm a nutter....hahaha.....or just a little eccentric.....
thats my take on lube and has served me well over the years......
I hope this will get u thinking of corrosion........perhaps even help a little ?......
just a thought, u need to know that special dissimilar metals, esp st/steel need a special lube to stop corrosion........look it up, it's all "velly interesting" remember Hogan's Hero's........
g/bye for now, it's Latte time.............Frank
try it,
