hi guys i have a sealey supermig 235 when i fire it up the gas is constantly coming out of the gun even without my finger on the trigger any help much apprciated
you will need to check if the welder has a gas solenoid in the welder if it does its probably stuck and a tap with something may sort it out or if it has a gas valve in the torch its self if it does it may also be stuck but you will need to srtip it and clean also check the spring is ok
defo one in the machine had a good look today took it it off and give it a bit of a clean with some brake cleaner gonna put it back together tommorow and give it a try,then its going up for sale as in a moment of madnesslast night i bought a portamig 235 off weldequip
