John Payne
New Member
- Kent
Hi , I have just put a new liner into my mightymig 150. On feeding the welding wire through using the gun trigger the welder stopped. On taking off the main cover I could see the welding wire had jammed in the liner and had found its way into and around the pcb causing a short.
I was not sure as to how much damage this may of done and looked to the internet for some answers.
I wanted to check if the transformer was still working. One feed said to use a multimeter across the rectifier where the 2 wires from the transformer joins to it and got no voltage, the third wire seems to go to a little box on the pcb . If I leave 1 multimeter lead on the rectifier and put the other to the case earth I do get a voltage.
How do I check if any other damage has been done. Many thanks John
