like the metric adjustable wrenches
Bahco's have metric graduations on them so it's not as stupid as it sounds. I wonder if the Bahco for USA have imperial on them
They would have to.
Why wouldn't they stick metric on one side and imp on the otherHere you go, trouble is, it will not fit any metric nuts and bolts.View attachment 262708
the wera ones i use are 8 quid each and only last a yearIt's worse than that:
If they have "wera" on them, they're 20 quid!![]()
need new ones now
But at least they last a yearthe wera ones i use are 8 quid each and only last a yearneed new ones now
Because then you’d only be able to undo metric and tighten imperial or vice versaWhy wouldn't they stick metric on one side and imp on the other
no there fine just the tips rouned off a bit and cam out ive just took a grinder and touched the tips up on the phillips driverDo you find that the tips on them break off then? Like with my experience of the RS ones, the cross head were the worst, a year or so of daily use, then a section of the tip would shear off.
its looking promising to prolong its life the thing is it gets used daily on dry lining screws that are hardened and it takes its toll it dont help when idiots borrow them and use them on pozi screws . some folk dont know the difference
I'm ambidextrous..... do I have to buy both?
wouldnt bother me im left handedId give my right arm to be ambidextrous ,,,,
