Not really. Every mot mine has a full service.There's no reason for an MOT guy to check your oil level at all!
Irrelevant
Irrelevant
I’ve paid for 2 jobs other than mots in 18 years of driving
Not having an mot won’t affect me as I make sure my car is spot on
What about it ?What about when the tester uses the oil temperature probe to check engine temperature?
No I had enough room when he pulled in I no longer did.. Can you please tell me how the heck you manage to leave double stopping distances on a busy a road ?Pot, kettle, black. ... if you needed to brake to let him in then you were too close to the vehicle in front.
What about it ?
1) they care not about level
2) they are allowed to bypass the check
3) many modern cars have no dipstick and it's a non-dismantling test so they cannot access it
They also rarely connect RPM sensors
most likley a light on the dash ..if it still worksI've heard that some vehicles don't have dip sticks so what is an owner meant to do if the engine happens to use a drop or two between oil changes??
Well that would appear to be easier than acknowledging you are wrong and the mot guy does not check you oil level for youYou appear to be looking for argument rather than a discussion, I'll let you continue to look.![]()
You're disagreeing with Kent while saying you do the same thing he does.always get some numpty who pulls in but ease off and create the gap again.
Yes im disagreeing with the statement you can't leave a bigger gap in traffic when the roads busy.You're disagreeing with Kent while saying you do the same thing he does
That would have cars parking folk at the side of the road in winter to freeze to death on a mountain where the person may have been able to continue with caution or decided that their life was worth more to them than a wrecked engine, but it wouldn't be worth more to the manufacturer than a warranty claim.Same here, although until cars become fully aware/driverless and can shut themselves down when a fault is sensed, it's best that the mot stays I think.
Not out of context, the important points so as not obscured by the rest. As said twice now, you can leave sufficient gap and if the person that pulls in front nearly takes your nose off you still need to brake.Yes im disagreeing with the statement you can't leave a bigger gap in traffic when the roads busy.
If a car can pull in front of me easily im obviously leaving more than a 2 second gap.
Stop taking quotes out of context to suit your arguments.
So what happens before the next service ? the car drives around with less than the correct amount of oil in it ? what a bunch of muppets. All engines are allowed to burn a certain amount of oil per mile, in theory the service interval should be short enough so the oil doesn't fall below minimum before the next service is due.Neighbour of mine religously took his car into our local garage for its regular service. One day after his service he noted oil level was on minimum. When he went back to the garage they said they only ever filled it to the minimum mark. The dipstick was marked 1 litre between min & msx. So based on an average car capacity of 5 litres to max the garage was getting the oil for every fifth car serviced for free. Needless to say he takes his car elsewhere for its service now.
RonA
I'm not in favour of removing peoples fate from their control , I'd always rather be an Morlock then an Eloi
Look at the amount of people, ok few, killed by faulty "fly by wire" throttle which coupled with auto trans that won't let you pick a wrong gear meant they could neither select neutral or step on the clutch and just let the engine blow.
The "self drive" car that could not tell the sky from a truck.
The plane crashes where they conclude that pilots should fly more and trust automation less.
Don't get me wrong, as said earlier I am completely in favour of a yearly MOT.
I do understand no MOT for older cars as driving older cars I know the MOT guys that aren't as old as my cars have insufficient experience to judge what is normal for these cars.
No MOT for over 40 year old cars does worry me. My wife's 77 car that I have not finished restoring due to rust could technically be put straight back on the road. Barn finds that were in atrocious condition are now suddenly legal (though obviously defects could be ticketed / earn points at the side of the road but in recent years the vehicle defect notices has plummeted from hundreds of thousands to a token amount as they focussed resources elsewhere, hence all the lights you see out on cars.
Kent's original post implies in no way he is too close, the rest is just illogical extension of argument but if you go back to the original he is neither pot or kettle.
I'd be reporting the garage to the trading standards as they are potentially risking customers vehicles so they can save a bob or two, I wouldn't be surprised if they are billing the customer for enough oil to reach the max mark either which makes it fraud as well.
