rtbcomp
Moderator
- Sheffield UK
is the psi you refer to the continus that the compresser can work at? mines set to cut out at 150 once had a m8s over 300psi as the shutoff valve was frozen first we knew of it was the bloody thing started bounceing around! quick run to main fuse bored and let preshire off from a distance lol
The PSI is what I measured at the tank with zero flow, it will be less at the nozzle of course. I have my regulator set to 90psi.
i used to blast clean vintage motor parts for a company who restored cars . either using grit fine sand and beadblasting at whatever presure it took as not to damage them
but i make even more now for easier work doing out of hours electrical callouts for a couple of large companys
