Ive got a proper pipe for the compressor but theyve got the wrong fittings on them and I didn't have time to go to town for new ones, but my gun has got an adjustor on it so I kept air flow down to a minimum and to be fair not much paint was wasted, Ive also seen how you elimate water from the air on other threads and It went straight over my head can someone tell me a simpler way of eliminating moisture from the tank thank you
Drain the tank down at the end of each session with the bottom drain to get it out the tank, and fit a water trap on the regulator that you drain after too, that gets most of it out.
One of these on the line near the gun helps too as it catches any moisture in the airlines too. You can get automatic drain valves for the compressor that do it for you when the pressure drops low enough (ie youve switched it off completely) but turning a tap is cheaper
http://www.justoffbase.co.uk/In-Line-Water-Trap-Filter-Sealey-ILF-SE
no number plate
. but they do hold there money very well but i hate drving them because of the heavy clutch
