AndyStobbs
- North West England
Still not sorted out why the HF was problematic. Yesterday I removed the enitre HF generator unit to try and see if there was a wiring fault.
Am I right in thinking the first stage is power connected across a capacitor and resistor in parallel which in turn is in parallel with a transformer primary. The secondary is then across two more capacitors, in parallel with the spark gaps. It must jump first one spark gap then the next before being run into a hollow coil affair, through the centre of which the main welding current passes on a copper bar.
The contacts for the spark gaps where very blackened and burnt looking, so I faced them up on some 1200 wet and dry, and gapped them to 0.2mm.
Have only done a small amount of playing around with the set since - not enough to know whether its fixed or not - but it seems so very simple in construction that I don't see what else could be wrong with it.
