wheresmejumper
Banned
cheers, problem i've found when visiting local electrical factors is they struggle to get an mcb if its not the same manufacturer, apparantly they are all slightly different clips to fit on the din rail and in the enclosure. some fit in one which might not neccessarliy fit another.
will proabably change to the rcd 63a switch and a type D 32a MCB. lights are on a differnent supply
thanks again for all your input
they should fit a DIN rail,its standardised.you can have trouble fitting bussbars when using different breaker manufacturers,but this can be worked around.
