BrokenBiker
- Newport, South Wales
right, this r and a lathe just will not run properly on a balata type belt or leather belts either. they slip, wont tension if I try, just stretch and even with belt dressing on them the first sign of load on the part and the belts slip again.
I want to try a rubber belt, but don't know where to get one, I can get belts for myford ml7 but don't know what size they are. I need a 18mm wide belt, length isn't too much of an issue as I can just alter where the motor will sit when I make the table to account for the length.
I sat down and worked out the ratios of the various pulleys between the motor and headstock, and it works out that the motor will spin the head stock at the same speed without the other pulleys, when I can get it to grip and to be honest I just want it to work so I can use it to turn dia on non critical jobs when the more accurate chester is laid up with a job in it
