the larger pulley on the chuck shaft is 1200mm and the measured rpm on the chuck is 480. No matter how I try the maths I can't make this add up, it's 'out' by about 10x.
Any ideas?
Regards
Peter
) but as yet it hasn't left the back of the fag packet yet.
) but I think the ability to calculate the correct rpm by the device depends a lot on the reflective 'spot', ie most of the designs specify more than 1, if you have the space, as this increases accuracy as long as the counter can trigger fast enough.
Yes, motor speed is tied to mains frequency (50/60Hz).
Single pole will try to rotate once per AC cycle 3000/3600
Double Pole will try to rotate one half turn per AC cycle 1500/1800
Triple pole will try to rotate 1/3 turn per AC cycle 1000/1200
Quad pole will try to rotate 1/4 turn per A/C cycle 750/900
There is some slip in the core, usually 50-60 RPM.
Wanted to measure my drill but my RPM gauge only works outdoors. Inside it will always read 3600 RPM as it picks up the flicker of the lights. Or it will give odd readings.
