Ok so im trying to do some restoration work I bought a used apollo 1500 3 stage sprayer I have a 0.8 pin .
so I sprayed up with primer the first part which was ok came up a little rough but with dome 600 grit it smoothed out no prob so after waiting for the primer to cure I layed down my base coat 2-3 light coats followed by 3-4 heavier coats but im left with a very rough surface im thining the paint on a 1 to 1 ratio as instructed on tin but it just wont lay smooth and when I try to flatten it needs so much work I end up going through the base onto the primer.
Any clues on what im doing wrong I know guys have had better luck with these units so there must be a way.
