Richard.
- Cambridgeshire
like dale said if it’s a mock up. A demo piece in which case what does it matter.
I know nothing about the item, what it does and what it’s done. What I do know is what a decent weld looks like from a defect inspection POV. I also have a firm understanding of typical criteria on welding defects and there allowances. Zero tolerance isn’t always practical so there are allowable tolerances on defects and craters on aluminium are typically a max depth with No limit on diameter last time I looked at a criteria spec on them which was for a company making scaffolding braces with tig.
Yes it’s quite a bit more tricky if you don’t have facilities to slope off. As you can’t control solidifying times. You would then need to do a patch up with low current re strikes and touching up with thin fillers. A bit more of a ball ache.
My 06 fireblade had Short weld on the swing arm that cracked 2/3 of the way across. It looked to of started from a small crater. In fairness with the rest of the design in the swing arm that weld could of failed completely and not caused any ill effect. I still re welded it mind. To me a crater shows laziness and laziness is something I’ve never really tolerated so the defect has a little grind on me when I see them because it’s like leaving something unfinished. Open box section on fabs pees me off in much the same way
It’s easy to look at stuff through today’s eyes and criticise but everything needs some context.
