normspanners
I know about the calcs but he hasnt mention a length but I now see you have based it on a guesstimate
Although you will suffer volt drop, You dont want to have any if possible, to give everything as much chance to start as you can, marginal anything on single phase is not really good enough because as the volts go down the current rises and doesnt do anything much good, my mate had the same problem trying to get his new 8kw compressor to start, the static converter was singing and dancing and not happy, to start it, crazy as it may seem I had the idea to start and run the lathe, (which btw would previously brown out the lights on its own!) we started it before the compressor and left it spinning the big the 4jaw chuck , because that then kind of turned his system into a rotary system, but the main thing was it create a flywheel effect ie a store of electricity and the compressor would fire up ok, we ran a new main cable in because it was 4mm before to 16mm or maybe 25 cant remember now, and the motor will now start on its own no issues, without putting the lights out.With converters its almost all about the peak starting volt drop
It does sound that way, if you go for a converter you will probably need a supply upgrade.got a proper look at the cable and measured it with verniers..it's just under 15 so looking even more like it won't be enough
Only writing I could see was "gap (maybe cap) electrical cable company limited 600/1000v"
an issue we used to have with the table saw killing the lights,
There is your answer
