I've been reading the safety aspect of 2k paint for the diy-er and the pros and cons of 2k compared to 1k celly and so on. My understanding is that unless you have a proper air fed mask it's not a risk worth taking. At the same time I don't think there is anything that compares to 2k durability, what did come to mind is that what if the base is sprayed on as normal and the lacquer which has all the nasties in it is rollered on, there will be no spray so less to actually inhale and I suppose you can also use a cartridge mask for added safety the finish of the lacquer won't need to be perfect since it's going to be cut and polished, what do you think?
