Here’s mine all done in Ferguson grey enamel. Didn’t replace the bearings, redid the grease nipples and once repacked they were perfect. I used one of the link style belts so I don’t have to disturb the shaft.
Oddly enough the end caps are brass. This one also was in the Kellogg’s factory only discovered after I stripped the many layers of paint off.
also sat mine on 90mm box I had with 6mm rubber bolted to the bottom found it a bit low to use for me otherwise
Left it 3 phase runs really nice and smooth only wanted mine for dressing drill bits and tooling got fed up of the cheap bench grinders!
