londonsean69
Migalomaniac
Hello boys and girls.
I have had a search of the forum and the tinterweb and can't seem to find a conclusive answer.
How do I work out what length of pop rivet I need?
Example, riveting 2mm ally to 1.6mm steel tube (kit car floor), I will use 3.2mm dia (1/8") but how do I work out what length I need?
Obviously I need the thickness to be joined, plus a bit extra to allow the inner 'head' to dome out, but how much do I need?
An answer or a pointer in the right direction would be great
Cheers
Sean
Edit - have found the answer
The spec is Dia x Max thickness, the actual rivet is a bit longer (obviously the stem is a lot longer)
So, a 3.2x9.5 rivet can join 9mm - I think
2nd edit:
The above might not be totally true, as some places give the rivet size as the length of the body, and not the thickness.
Arrrgg
Cheers
Sean
2nd edit:
Arrrgg
W/A
